Fillet Question
6806.4 In reply to 6806.1
Hi jetblast, the more that I look at your case there, the more uncertain I am of exactly what kind of result you want to have...
It seems like it will be difficult for the fillet to go down to zero radius at the tips there and still interact very well all the other surrounding surfaces.
If you have a piece like this:
That will make the "taper to 0 radius" part have to be a sudden shift in shape and try to abruptly taper off, that has some difficulty.
If you try to make it do it more gradually, then it's probably difficult for it to fit exactly within the available space... it would still probably have to be a sharp corner in that area similar to the ViaCAD screenshot above, probably some of the fillet would be sliced off...
