V3 beta Jun-27-2014 available now
6790.3 In reply to 6790.2
Happy late birthday eric, I'm glad that the new face extrude with built in booleans will be useful!
Here are the notes on that particular part:
Extrude auto booleans for faces. Make a face sub-object selection automatically boolean the extruded result with the base object. Allows for "push/pull" type action with Extrude command. When extruding a face of a solid, going outwards from the solid makes a boolean union of the result, going inwards does a boolean
difference. With an open surface, the extrusion is merged with the surface and the original face is removed to make a pocket in the surface. The auto boolean behavior can be disabled by setting the "Keep separate" checkbox in the extrude command options.
I think it should cover some stuff that you've asked for previously and also the type of stuff Andrei was asking about here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6693.1
EDITED: 28 Jun 2014 by MICHAEL GIBSON
Size: 294 KB, Downloaded: 31181 times, Dimensions: 502x346px
