Hi shayne,
> Would you consider adding the Customui that Max wrote ?
No, I haven't really thought about doing that. I do want to include something along similar lines in the future but I haven't had a chance to do it yet. For example the lighting options I would probably end up putting under the View palette rather than on the bottom toolbar.
But by all means if the customui helps you out you should install it - that's what's nice about being able to customize MoI, that you can use extensions that help you out.
