unit conversion
6773.1
I usually work in centimeters, sometimes in millimeters if it's a really small thing, but when I export to .obj, I first have to convert the units to meters, or else the scale is wrong when I import directly into MaxwellRender. there are no import options like in C4D to change that on the fly.
so I keep switching between meters and centimeters, which is a real hassle. (click options, switch unit system from cm to m, click close, export, click options, switch unit system from m to cm again, click close) to continue working in MoI.
I can't work in meters in MoI, since the (scrollwheel) zooming etc works awkward when closing in on small details.
is there something that could simplify this workflow?
tnx
wim
