New tutorial!
6755.15 In reply to 6755.11
> yes but if I don't choice rigid Letters are pespective deformed that I don't want! ;)
Right, so Flow just does not do the particular job that you want there, you would need to use some other method for rotating your text, such as Transform > Rotate, or Transform > Orient...
In the future when there is such a thing as a "Group" in MoI, it would then probably work to make Flow with the Rigid option take the center of an entire group rather than just each individual object and that would solve your particular issue here.
