Pipe script
6721.4 In reply to 6721.3
Hi Andrei,
> Michael, I have alwas click here to update result.
That's something I guess I added to Pipe2 to support the tapering option a bit better.
If you get the original pipe version it should behave like you're asking about.
First get the files from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1463.9
Then get the updated Pipe.js file from here:
http://moi3d.com/forum/display.php?webtag=MOI&msg=4438.41
That version of pipe should update automatically when you change a radius value.
> I know about second method just wanted to know if it possible to have via script.
It's certainly possible but it would probably take me longer to code and test it than the amount of time that you'd end up saving using it. Just drawing a rectangle and using sweep does not take very long already...
