Curve from two surface intersection
6698.3 In reply to 6698.1
Hi Sharif,
> Do you have any idea what is casing this?
It appears to be happening because one of the surfaces has little bumps and waves in that same area. So the intersection curve is just following the shape of the surface there.
You can see the bumps a bit more easily if you hide the green object:
