Curve from two surface intersection
6698.1
Hi
I use Isect command to generate a curve from intersection of two surfaces ( see image1). if you look at the curve closely (see image 2) at the top and the bottom the curve is not smooth as the rest of the curve. Do you have any idea what is casing this?
sharif
Size: 231.7 KB, Downloaded: 59 times, Dimensions: 760x560px
Size: 134.8 KB, Downloaded: 58 times, Dimensions: 748x945px
