Extrude/Shell request
6693.19 In reply to 6693.14
@Danny,
> Having a look at Inset and when 'Use separate height' is checked is it possible to have a
> zero thickness, at the moment it's not accepted, in that way I think that would suit
> Andrei's request.
I don't know... Inset is primarily focused on generating a border, with the border thickness as it's main input field at the top of the command.
So it seems kind of awkward to focus on disabling thickness inside of it. For example since the command is primarily focused on thickness when you pick 2 points with the mouse it sets the thickness, not the optional "separate height" height.
It seems like it might fit better as an option in Offset, maybe something like "build side walls"... The thing that makes me pause about that is that there is then some duplicate overlap functionality between offset and shell, since if you select an entire surface object Shell will thicken it with side walls constructed already. The main difference would be the behavior when there is a face selected instead of a whole object selected, shell uses that as the opening and thickens everything else.
