How does one exactly place an object?
6688.4 In reply to 6688.2
Hi DesuDeus,
> you can pretty much use TAB then value for anything :)
You usually don't even have to use tab, if you just start typing numbers the keyboard focus will go into the first available numeric input field for the command, or the xyz input control on the bottom toolbar if the command does not have its own field.
You only have to use tab first if you want to put in something other than a numeric entry (like typing in a command name) or if you've set up keyboard shortcuts for numbers or something like that.
