Set - Control Points (Show points) number
6677.2 In reply to 6677.1
Hi Paul,
> Is it possible by any chance to set the amount of the Control Points (Show points) on a surface.
Sorry no there currently isn't any way in MoI to do that - there is a way to do it for curve objects using the Rebuild command but currently the Rebuild command only works on curves and not on surfaces. I do want to make it work on surfaces in the future though.
Just in general surface control point editing is not really a big focus area for MoI - MoI is overall more focused on drawing and editing your curves first and then generating your surfaces from those curves and not very much on tweaking the surface points directly. Sometimes if you're trying to edit surface points directly it may be a sign that your object is really better suited to be constructed in a polygon editing program where that kind of point cage tweaking is the main way to construct things.
With NURBS modeling there is much more of a focus on drawing 2D curves and generating your object more by a type of construction workflow, using some curves to generate objects and other curves to cut them up, just in general surface point tweaking is not really the main way to build things in MoI.
