Looking for advice on .stl export for object with flat curves
6672.9 In reply to 6672.8
Hi Rick,
> Bottom line is that MOI feeding a slicer seems to do a mediocre job when you crank up the
> resolution on the .stl. I've seen the same issue using Cura and Kisslicer.
Do you mean you saw these results using the settings I just posted a minute ago?
If not then the bottom line is that you just needed to just adjust a few settings to generate a denser mesh.
