A question/request about the great moi3d
665.3 In reply to 665.1
Hi Giulio, fantastic model there!
I want to add more display options, such as turning off edges like you want, but currently I have planned on adding these options in for version 2.0.
But there is something you can do with the current version - it is possible to hide edges which should give you the display you want. The edges will come back after you do any edit to the model, but it should be pretty good if you want to stop editing and do a visual inspection.
To do this, select one edge of your model, then do Ctrl+A or Select / Select All - this will then select all edges and you can use Edit / Hide to hide just those edges.
I'll also see if I can set up something to make it possible to do a script macro on a keyboard shortcut to automate the above procedure.
