Join versus Merge
6631.5 In reply to 6631.4
Hi Metin, I've had some ideas about maybe combining those commands together so that maybe after you do a join it would ask if you wanted to merge together segmented pieces or keep the segmentation but I haven't quite figured out how to work out the UI for that yet.
Currently Join does not reunite edge pieces, when you run join on edges it just takes the edges as curves and generates a new joined curve result.
