Linux and Moi3D, newest betas
6620.6 In reply to 6620.5
> What would be correct (Windows) directory for the .ini? I can edit it manually, if
> necessary (with DOS/Windows format, of course).
Under Windows it will put it under %AppData%\moi\moi.ini
When it's running under Wine it's supposed to put it instead under ~/.moi/moi.ini
You can also put it in the same directory as where moi.exe is at, it will look for it there first and use it if it finds it there.
