How to create a catamaran hull nose using sweep?
6590.2
Yep, trying to finish off the tips of airfoil shaped objects has always been a problem in MoI.
The latest beta's of V3 have the ability to loft to point which should solve the problem for you.
Add a point to the nose of the hull and loft between your cross sections. You may need to add more cross sections in the nose area close to the point to get it to give you the desired shape.
If normal loft isn't giving you desired results, try the samardac method of loft, loose, exact.
https://www.youtube.com/results?search_query=moi+organic+loft+samardac&sm=3
~Kevin~
