Got stuck in trying to create a loop wheel....
6577.8 In reply to 6577.6
Hi Yves, yeah sorry I didn't understand the kind of alignment you were looking for at first, I thought that your current model was already shaped close to what you needed.
So right now with only a planar path for the sweep you won't be able to make that shape you'll need to make a longer path curve that is not planar, it will need to shift over a bit instead of being all flat. One way to do this is to draw it initially flat and then select some points and move them from a side view so you can introduce some out of plane shifting to it, check out the side view of shayne's path curve above.
Another way than that which may work is to use the Flow command to map a rising angled line that marches along your planar base path. There is some description of this method here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4785.13
http://moi3d.com/forum/index.php?webtag=MOI&msg=4877.14
That lets you do produce a non-planar result in a more sort of construction manner, starting from 2 planar curves, one being a base profile and other being a sort of elevation control.
I'm heading out for vacation in just a bit here so I may not be able to help you with this much while I'm traveling.
