Got stuck in trying to create a loop wheel....
6577.6
Michael,
After re-reading my post I now realise that I did a bad job in explaining my issue. Let me try again...
Each fiber spring consists of 2 separate (off-set) pieces that are joined in the middle. The left section starts with an off-set to the left but then twists so that it ends up in the middle of the wheel rim. The right section starts with an offset to the right, twists and ends up in the middle of the rim on the opposing side.
As you can see in the picture, (see "A" in picture below), both off-set sections are fully aligned in the middle of the rim.
Yves
