Blend help please
6568.2 In reply to 6568.1
Hi Robert, can you please post the 3DM model file instead of just a screenshot? That helps a lot to answer questions when we're able to look at your actual geometry.
My first guess from looking at what you've got there is that you probably have some curve objects selected there, which are occupying the same exact space as the surface edges.
In order to make a surface blend you need to select 2 _edges_, not just 2 curves - the edge is what is directly associated with the surface and that's what Blend will look for in order to generate a surface result.
So if you have curves in those spots, hide or delete those first to get them out of the way so you can select the edges.
Then you'll probably also need to configure that a little bit differently, you usually need to leave some more open space than that between the things you are blending, but you'll see why once you are generating some surfaces.
