File not found error
6555.13 In reply to 6555.12
Hi Michael C - drag and drop is supposed to work though, but in v2.5 if I remember right there was a problem when certain characters where in the file name or directory path, like * or / characters.
But this is supposed to be fixed in v3 - if it's not fixed and you can figure out which particular characters are causing the problem please let me know so I can try to reproduce the problem over here and get it fixed up.
The handling of drag/drop is quite a bit more complicated (with more layers between MoI and the operating system handling various things) than the File > Open menu so it's pretty likely that the file menu will not have the problem.
