Is there a way to script getting the center point of a circle, without picking the center point with the mouse?
The center point needs to be the same data type as a picked center of a circle.
I have successfully created a 3 point circle with script:
var startPt = pointpicker.pt;
var radiusPt = startPt;
circlefactory.setInput( 0, startPt );
var endPt = pointpicker.pt;
circlefactory.setInput( 1, endPt );
circlefactory.setInput( 2, onPt );
circlefactory.update();
var invCircleObj = circlefactory.calculate();
var invCircle = invCircleObj.item(0);
//	var centerPt = vM.createPoint( 0, 0, 0 );//Test: Right type, but wrong location.
//	var centerPt = invCircle.center;//Test: centerPt is wrong data type.
//	var centerPtxyz = invCircle.center;//
//	var centerPt = vM.createPoint( centerPtxyz );//Does not work, parse error.
/*	Does not work:
	var xc = invCircle.center.pt.x;
	var yc = invCircle.center.pt.y;
	var zc = invCircle.center.pt.z;
	var centerPt = vM.createPoint( xc, yc, zc );
/*	Does not work:
	var xc = invCircle.center.x;
	var yc = invCircle.center.y;
	var zc = invCircle.center.z;
var radiusValue = moi.vectorMath.distance( centerPt, radiusPt );//TEST, works for picked points.
(If it is not possible, I have added code to mouse pick the center of the newly created 3 pt circle.)
Thank you,
Ps, I had a similar question about invCircle.radius, to get the radius value, but have the radius value
By vectorMath.
