Hi OSTexo,
> Is there any way to dynamically change the pitch of a tapered helix while in the command?
There isn't any way to adjust it with only the mouse, it only accepts typed in values.
> e.g. to be able to determine thepitch by snapping part of a curve to geometry.
You could get this one done by drawing a line before doing the helix, then open up the size dropdown (from the properties dropdown), and select the length of the line there, use Ctrl+C to copy it. Then when inside the helix command use Ctrl+V to paste that value into the Pitch field.
