v3 beta ??
6508.2 In reply to 6508.1
Hi Robert,
> one problem it fixed in v2 which I had a problem with was that starting v2, only the 3d
> windows appeared with no left or bottom menus.
> 3d systems tech (from alibre) help said cause might be my graphic card
This is a bug that got introduced in Internet Explorer v9, it may go away if you close down Moi while it is maximized so it starts up maximized, or possibly if you right-click on the MoI shortcut and under Properties > Compatibility set "Disable desktop composition".
V3 though does not use Internet Explorer anymore and so will not run into this.
> after the the v3 beta trail expires can you continue using the v3 beta. might
> be a while before I update since I just bought v2?
Yeah the v3 beta is totally separate from the trial, the current v3 beta runs until Jun-22, so it does not expire for quite a while yet.
> still have v2 installed. any problems with that?
No problem with that, you can have v3 and v2 both installed side by side.
> make any difference where I get v3 updated from, alibre (geomagic) or Moi when I do get
> v3 release? do not know how alibre is going to release v3.
Won't make any difference where you get it from, it will be the same thing.
