| Hi Death, what you are showing there is a customized side pane, you probably got it from the dark UI customization.
 > I didn't change anything with the sidebar except adding the script in the startup folder.
 You must have done so in order to get what you are showing.
 If you didn't make a backup of the original UI before modifying it, you can get it by doing a reinstall.
