| Hi Mr. Yuri,
 > 1. Now when I open MoI with Darktheme I see almost all icons (or sections?) collapsed.
 > Is there a way of choosing which sections will be opened at startup. I'm noob-programmer.
 Try this - unmaximize the MoI window and stretch out the non-maximized size to be large, then close the window so that will establish the regular non-maximized window size. If the non-maximized window size is small I think that can cause the type of issue you are describing.
 > 2. @Michael. maybe hint for later release. Would it be possible to map a command into Options> shortcut keys> map
 > a command by clicking on something?
 I do want to work on something similar to that in the future.
