| Hi Mr. Yuri, if you create a folder named "appdata" inside of the MoI portable folder as a sibling to "commands", "ui", etc... then MoI will use that folder as its appdata location instead of the regular spot. So you can use that to make a portable set up of anything that is designed to be in appdata.
 > Super benefit would be if I won't have to go through same complicated process of customization
 > over again if newer version of MoI is released.
 I'd recommend setting up whatever you can inside the appdata folder and then you would just need to copy that folder over into the new version.
