| Hi Suzanne,
 > C:\Users\<username>\AppData\Roaming\Moi\
 > I'm unable to find this folder with my usersame.
 Try using Win+R to bring up the Windows "Run" dialog, and then put in:
 %Appdata%\moi
 That should then open up the MoI userdata folder. I think it may be in slightly different locations on different Windows versions but there is an environment variable named Appdata and if you put % % around it like above it will substitute it in.
