| """"""""""For lighting options I seem to remember that some modules of CustomUI are not enabled by default, you need to enable them by something like removing a leading character from the filename which CustomUI looks for and skips that module if its present."""""""
I think he is referring to this?
My "Lighting options" is a js file stored in the "scripts" directory, which creates a dialogue from "LightingThemes.htm" located in the ui directory!
So mine came back, when I told Customui to look at my "scripts" directory!
I modify a second scripts.menu.htm to draw from the scripts directory, so I can separate a few things out from commands.
I am pretty much guessing if this mod is proper and legit. Things changed a bit from the last version! |
