CustomUI
6507.136 In reply to 6507.135
Hi mike, that's great that you've got it working!
> I don't see all the objects that were shown in the first thread, gear,nut, bearing etc..
That seems to be normal - there's only 3 included by default in this particular package.
I think the main idea is you can add your own objects in there. If you select an object you want to put in there, open that menu and move your mouse to that title text that says "Object library". A plus mark will appear and when you click there it will put up a dialog for you to put in a name and that will make a new entry in the menu.
If you want some objects like that gear and what not, you can get a bunch of stuff like that over at http://grabcad.com .
