Import from Rhino to Moi3d ---export .dxf quad meshes
6505.2 In reply to 6505.1
Hi Kreten, MoI's DXF exporter (which is new for MoI version 3) is focused on 2D drawing output, generating stuff like lines, arcs, circles, etc... - not mesh output.
But Moi does do mesh output to several other polygon mesh file formats, one of the most commonly used is OBJ format.
What program are you trying to import your mesh into - why is it that you're using DXF format for the mesh transfer? DXF format is not generally very good for mesh transfer since it has limitations on the number of faces that can be in a single mesh.
