loft/sweep ?
6485.6 In reply to 6485.5
Hi bz,
> But lets say that I needed the surface to follow the lower edge (the side view trim line) all he way around.
> It looks likes the surface pulls away a bit towards the rear. I tried to use the trim line as a scaling rail but
> it doesn't work. What you've done is good enough for my needs but I was just wondering ...
That's why it can be good to make the sweep profile stick down a little ways past the trim line instead of trying to skim it directly along it, so that there's a little bit of extra material all around that then gets trimmed. That tends to be the easiest way to make sure it all matches up with the trim profile, with the profile cutting some material away from the entire surface.
Let me know if that does not make sense.
