Fillet
6454.4 In reply to 6454.3
Hi jetblast, can you please post a 3DM model file with your loft or sweep object in it where you're seeing the problem?
Do you mean that the radius value that you want to use just doesn't work?
It might be that if you're trying to use a larger fillet radius on one side, that there is not enough space in the model for the fillet to fit once it tries to trim things to make space. When things come to sharp angles to one another it's possible for fillets to eat up quite a bit of the model in order for them to fit.
But it's hard to speculate on what in particular you might be running into, there are a lot of different possible things that can cause fillet problems. If you can post your model file that will help a lot to give you some better more specific feedback on your problem.
