Boolean with a loft question
6429.2 In reply to 6429.1
Hi Dan, it's difficult to answer your question very well because I can't seem to repeat the same problem over here...
I tried doing a loft between 2 of the polylines that I thought you were referring to, and then then when I tried to boolean the lofted result from the box top it worked ok for me over here.
Do you possibly have the failure case saved off so that I can load a file with the pieces ready to go to reproduce the boolean failure?
What version of MoI are you running, v2 or the v3 beta?
