network command nuances
6427.6 In reply to 6427.1
Hi Stav, also attached here is an example of the kind of layout you would need in order to do a network on this.
But I'd think that probably Sweep would be better for you anyway though, the way that sweep works is by sliding the profile curves along the rails, because of the way it works the shape of the profile curve is rather more rigidly maintained throughout the generated surface than Network.
Network is sort of more like putting a membrane on the wires, the generated surface will have a certain element of slackness to it when it is in areas in between profile curves.
