Hard surface simulation software
6399.8 In reply to 6399.7
there is something called dxf2phun, which should convert a dxf file into an algodoo readable.
http://en.sourceforge.jp/projects/dxf2phun/
it's a pretty straight forward, drag&drop application. the output is a script(thyme), which you can paste into algodoo (shortcut F10 in algodoo brings down the console window). i did use it with some older versions of algodoo, but as i can recall, dxf2phun is quite picky regarding the geometry it's been fed. i had more luck with svg2phun
http://www.geocities.jp/int_real_float/svg2phun/SVG2Phun.html
via. uniconverter(ai to svg), as there is no native SVG export option in MOI.
http://sk1project.org/modules.php?name=Products&product=uniconvertor
