animal clinic
6384.1
Hi Michael ..
I built the model entirely in MoI. It was rendered in Flamingo NxT via Rhino 5 and still needs some Photoshop touchup.
It probably took longer to assign the materials in Rhino than it took to build the model. I have had some passing thoughts about The Plant Factory. Most rendering tools have no available plant material and NxT does so I stick with it though other render tools do produce better results.
The animal hospital is fairly small (less than 3000 sq ft) with an apartment above.
As usual, MoI is a joy to work with. It is more fun than work, actually.
cheers,
eric
Size: 424.2 KB, Downloaded: 311 times, Dimensions: 1654x798px
