Hi Rudy, if you change those 2 settings in options ( Surface angle and Trim curve angle from default 10 to 20 ), then I think it should work ok even on your lower memory machine (as long as its not _too_ low in memory... )
Does it still not work for you even with those Options changes?
But I should be able to make it work better without messing around with any settings.
