Issue with scripting and an object's 'locked' property
6317.3 In reply to 6317.1
Hi Jeff, also one thing that may be more convenient for when you're developing these scripts would be to put the script as a separate .js file in some spot like c:\scripts .
Then in the shortcut key if you put in a full path to a script file, it should load it and run it as "inline executed script" (as opposed to a "command" which has other kinds of setup and cleanup done before running) the same as code directly pasted into the shortcut key entry itself would do.
Then in moi.ini also set:
[UI]
DisableFileCaching=y
So that MoI will read in that script file from disk every time you run it rather than caching it.
