>Yes, I failed to mention the [enter] part. It's the way I currently work in AutoCAD. The thumb rests on the space bar.
>There is also another setting in moi.ini, under [UI]:
>[UI]... TreatSpaceAsEnter=n
>I have already changed that to y. I like it!
One little thing I noticed about "space".
Let's say you want to create a point at x=5 y=7 z=2
Normally you would type "tab" 5 "space" 7 "space" 2 "space" "enter"
But since you altered space key which works as enter you can't use space there.
Luckily Michael thought this possibility and you can use "comma" key instead of space there.
With your workflow, it's gonna be like this: 5 "comma" 7 "comma" 2 "comma" "space"
