Shortcut key command scripting
6309.1
Is it possible to script shortcut key commands without having to use modifiers (Ctrl, Alt, etc.)? I know you can use a single character for a command. Unfortunately, many commands start with the same character and you cannot enter two or three characters to initiate a command. For example, I would like to script something like this:
Rotate would be R or RT
Revolve would be RV
Rectangle would be RC or REC
I personally like using the left side of the keyboard for the majority of command calling without having to use the modifiers or function keys. Most of the shortcuts are written left to right. This also helps with not having to take my eyes off the screen.
I've also been in the moi.ini file as well as the .js and .htm files trying to see how things are written. I just don't have enough background in coding to try something myself.
