Hi Martin,
> I've just noticed that 'Export Type' is no longer present when saving as a DXF, so the choice between
> 2D Projection and 3D Curves doesn't seem to be there any more. I quite often need to export 3D curves
> to my CAM programs for engraving on non-planar surfaces so it would be good to get this back if
> possible - unless I'm missing something of course :-)
It should still show up and work the same as before when you are only exporting curves out to the DXF file and not any surfaces or solids.
Either hide the surfaces and solids and do a "Save As", or select just the curves you want to export and do File > Export to write just those to the DXF - the options and behavior will then be the same as the previous beta.
