Hi, Burr and Michael.
Both ways work well and I've got the fillets I wanted, so thanks to you both for your help.
Michael.
I'm pleased you found the problem and managed to fix it.
One further thing I have just noticed though.
If you select the outer boundary curve of the solid shape, the dimension is shown as 221 x 90mm which is correct. If you now extrude that shape down to say -15mm in thickness you should see that the sizes of the solid are now 220.996 x 89.993 x 15. Interestingly, when I check the size of the original solid it comes out at 221 x 89.997 x 15. Is that normal, or could it be causing a problem further down the line?
Thanks for all the help.
Martin.
