Hi Martin,
> Correct, I was never able to copy anything from Moi to Illustrator using the clipboard neither in AI nor PDF format.
Hmmm, over here it works ok with both AI and PDF formats going into Illustrator CS6. On the previous beta only PDF worked.
> But there's still a difference: the clipboard viewer shows "com.adobe.illustrator.aicb" after
> using moi.geometryDatabase.copyToClipboardAI(); and the successful Photoshop to AI copy
> uses in particular 'AICB' (CorePasteboardFlavorType 0x41494342).
Yeah sorry the first thing I wrote was not correct, the current beta has it switched to a type of "com.adobe.illustrator.aicb" which is what seemed to work with CS6.
> I'm afraid that CS3 is buggy in this regard since it's not even possible to copy from InDesign to Illustrator.
Seems like it could be a problem with CS3 itself...
But I'll see if I can switch over to using the old style 4-character 'AICB' identifier if that still works ok with CS6, and maybe that will increase compatibility with older versions.
