quote:  The copyToClipboardPDF() was working ok for others previously, do you mean that the PDF version did not work for you before?
Correct, I was never able to copy anything from Moi to Illustrator using the clipboard neither in AI nor PDF format.
 quote:  So after switching to using 'AICB' instead over here that fixed it up when I tested it previously.
But there's still a difference: the clipboard viewer shows "com.adobe.illustrator.aicb" after using moi.geometryDatabase.copyToClipboardAI(); and the successful Photoshop to AI copy uses in particular 'AICB' (CorePasteboardFlavorType 0x41494342). I'm afraid that CS3 is buggy in this regard since it's not even possible to copy from InDesign to Illustrator.
