Relative start
628.4 In reply to 628.3
Hi Rozen, you're welcome, I'm glad that works for you.
I have now fixed that problem for the next beta, so that if you set a distance constraint when drawing a construction line, the same distance constraint will not still be active and applying to the regular point pick after the cline is finished.
I've also added a way to turn off distance or angle constraint by putting in a 0 in either the d or angle boxes. Previously there wasn't any way to turn it off once you had turned it on.
> Looks like you can do it in any situation.....
Yup, that's the nice thing about these helper tools like construction lines - once you learn them you can usually use them for any drawing command, whether it's drawing a polyline, drawing a cylinder, etc...
EDITED: 9 Jan 2021 by CHRI
