Resolution of Image View of PNG file
Attached are 3 views of a pixel image.
Image one is a sample of a small portion of a PDF, from a scan at 400 dpi. It is a pixel image in AdobeReader11-0-5.
In order to add the image to MoI, the PDF was exported by the GIMP image program to a PNG, using 400 pixels/inch., which is the third view, in WindowsPhotoViewer.
The middle view is the image after the same PNG is added to MoI. With a little magnification, this third view does not show up as clearly.
Is there some way to improve the "resolution" of the Image View in MoI?
What is the "resolution" in MoI? Is there some other explaination for the way the Image View shows up, like "dithering" or "anti-aliasing," or something?
- Thank you, Brian
The goal is to "trace" the pixel view of the model, into MoI NURBS curves.
Size: 62.2 KB, Downloaded: 24 times, Dimensions: 687x480px
Size: 256.8 KB, Downloaded: 28 times, Dimensions: 932x628px
Size: 38.3 KB, Downloaded: 28 times, Dimensions: 1024x681px
