Hidden Points on a solid (copy)
6271.2 In reply to 6271.1
Points wont show on "joined surfaces" (more than one surface). So you can use seperate on the object and then points will show. Just know that moving points then will break the edges of the original joined surface and it will most likely need repair to rejoin correctly.
