I think Michael is planning to work on some additional options for Blend that would allow you to add definition shapes along the blend result and a method that tries to match the isocurves on a more parallel/perpendicular basis.
For now, try using Trim to cut the edge curves at points offset from the end, so that the Blend does not go all the way to the end.  Then try fulling the gap with an N-sided patch.
