Can´t open
626.14 In reply to 626.13
Hi Psygorn,
> When I click on MOI3D Icon it does not open! It does not shot any message
> as well! What should I do? ( Could it be a virus or something?)
Have you already tried rebooting your system? If not then try that first.
Also can you try pressing Win+R to bring up the Windows "Run" dialog and then put in:
c:\Program Files\MoI 4.0\MoI.exe
and push Enter? That way you can test if it's a problem with some shortcut you're using to launch it.
Also after you do that, open up Task Manager and see if MoI.exe is listed as running there or not.
> If I go to : C:\Users\MyName\AppData\Roaming\Moi and save all the files there Could
> I be sure I have saved all the changes I made to it?
Well it depends on what particular things you've modified. If you've done changes to files in the UI sub-folder in the install directory then you would want to back those up too.
