Hi Mike,
> I noticed that there was one "group" in Illustrator, which included the bitmap and a clip for the
> exterior of it.
> I can also see where your thicker lines reside lower in order than the bitmap, and the thinner are
> above, but they all reside on the same Illustrator layer.
Yeah this is because Illustrator does not read in layers from PDF files.
But it will read in layers from AI files, so if you want to get layers to go into Illustrator you'll want to use .ai format for the transfer and not PDF.
Can you test the above AI file (download both the .ai and the background image which is a linked image inside the .ai file) and see if the layers come through ok for you using that format instead?
> Could you consider putting the different separate 'layers' of line types within
> actual groups, if it will let you do that?
> Then we could just click on the group of lines and colorize it or whatever if need be.
I may be able to do something with making groups too, but probably having the layers come through using AI format will do what you need as far as making them targetable.
